Neumann U47FET Clone: D-U47 FET Microphone Project PCB Build thread
Thanks so much! I wonder if it works the same on the FET 47 transformer. I hear AMI are not very thoughtful in their coloring of their wires. I do appreciate you helping me at least see another AMI diagram with colors listed. How did you like the sound of your BV8?
Coloring in electronics is arbitrary except for (some) thru hole resistors and some ribbon cables.
There is no convention or standard for transformer leads, that's what data sheets are used for. Download data sheets for each and every part you buy for your builds, and read thru them.
Hey!
Could You please tell a source for the 220MOhm (or 200M and 20M) / 1W resistors!
I am located in germany…
Thanks and bye Friedemann
Just a silly question, looking at the original design i found that many polarized tantalums have been replaced either by electrolytics or film caps in the suggested BOM, is there a reason ?
Is it also possible to replace the 2,2 uf at C5 with a 10uf ? As far as i understand the schematic is it only here for decoupling ?
