Studio Mollan said:
poctop said:
Studio Mollan said:
dmp said:
Thanks for posting the clips.
Curious if you could do the calibration sweep of them and compare the amplifier response. See my post back on page 11 showing the response with the bv12
Wondering if the feedback winding on the T67 vs BV12 differ.
You're right. I'll try to do that. Couldn't you modify the feedback to work best with a certain transformer. The cap in the schematics is specified 80-160 so maybe trying different values there can "tune" the circuit to the transformer?
Anybody?
Also I would like to confirm that the output is wired for 200ohm or not. I few posts back someone said the clone didn't have the same output as an original u67. Different output impedance could be the answer to that question.
Emil
I can confirm that the output from the 2 audio coil are connected in series and connected trough the adapter board for the AMI and the main pcb for Max transformer
, meaning 200ohm output impedance not to be confused with DCR of the coil it self.
dAn,
Alright. Thanks for clearing that up for me Dan!!
Can you chime in on the hi end difference between my Max/Ami transformers? I know you did a voice test early on which confirmed the max version having less hi end/more saturated. What's your first impression listening to the clips a few posts back? Transformer alone or something I've done wrong putting them together? How would changing value of C17 alter the sound?
I did not heard your sample yet , but I will shorlty , and report back ,
I do like the "gritty" harmonics from IOaudio Transformer it really reminds me of the neumanish sounds,
as far a C17 goes it dictates the linearity of the High end the slope in other terms , so it might have to be adjusted for your transfomer,
i would suggest you put up the lowest values and then the highest value to suit and listen out,
DAN,
