So the Mouser BOM listed has extra stuff in it. Like 10, 1% 2.2k resistors so you can (hopefully) find an exact matched pair. And also, I think it has 60 megohm and 68 megohm resistors in it, when you only need one of those pairs. I think once upon a time the 60s went out of stock, so someone added the 68s without removing the 60s. The original circuit I think called for the 60s, but the 68s will work fine too. It also has 2 trimmer pots for adjusting your bias voltage for the FET. You only need one, and only one of them has the right pin alignment for the PCB.
Pay attention to how you install the 2N3819!
Also, where did you GET your 2N3819?
This is (all) explained in this thread:
http://www.vintagemicrophonepcbkit.com/Neumann%20U87%20Build.htm
Also, pay attention to capacitor polarity. It matters on electrolytics and tantalums!
This is probably not the best build for a beginner, because it is a little complicated, but good luck!
