Ricardus
WILL SOLDER FOR FOOD
1coin3lives said:Ricardus, I wasn't sure if your post was in reply to me, but I'll respond as if it were![]()
Yes, it was for you.
BladeSG said:I'm about to start this build using the SYT-5 body and Beesneez K8 capsule.
Do I remove the capsule from the Beesneez mount to go on the Chinese mount as the Beesneez mount doesn't look as though its going to be compatible with the plastic part between the chassis and capsule mount?
Anyone have photos of how this was done if you used the same body and capsule?
Ricardus said:I bought the capsule mount from Peluso when I bought the capsules.
I took out the plastic thing that came with the body, and mounted the Peluso mount in there. It just required drawing some lines and drilling some holes.
BladeSG said:Thank you.
So you removed the plastic part at the base altogether?
hazer-drum said:Did you notice any differences in sound between 2-10mA of Idss?
FarisElek said:I've built some preamps and fixed some compressors so I thought I was ready for this but I may have gotten over my head.
1) Totally not sure If I have the AML T13 transformer is in right as it has two yellow and two black wires which is kind of confusing. Tried my best to find connectivity of the transformer through holes to the XLR through holes and kind of guessed which black wire and yellow wire to the tranfo was which.
2) Tried biasing the fet using the multi-meter method. However, my turning of the Pot seems to do nothing. it stays around 8.5 volts.
3) Testing the mic has produced mostly electrical static-y noise, but occasionally if I jiggle the mic while testing I'll get my voice to come out for a second.
Please help me.,,..
Ryan
