Ricardus
WILL SOLDER FOR FOOD
Looks about like it should.
I built two with the blue PCBs.
FarisElek said:Okay, scrubbed it and it changed and the slowly went back to working perfectly in figure 8 and poorly in the other two positions. I think I can safely assume this is a switch problem? If i toggle the switch back and forth and turn it on, it will be weird in all three positions and then slowly go back to the way it's been. Where can I buy just a single 3 way switch?
Ryan
DT_Music said:Has anyone used the LA-8 Capsule from Luke Audio? I had been planning on using the Heiserman Capsule but prices seem to have gone up recently so I'm checking alternatives. Luke Audio mics have gotten good reviews and I just saw that he sells capsules for DIY builds. Here's what he had told me about the LA-8 (K87 Style)
"Yes, we make a K87. 34mm , electrically isolated, 1 micron Mylar, platinum sputtered, and are $250. All around a fantastic capsule, slightly brighter than what you may consider a vintage 87 but that depends on the circuit and how true it is as well"
I'm intrigued but I'm also going for as legit of a vintage 87 clone build that I can. Has anyone used these or compared them with the Heiserman capsules?
poctop said:If you are working on the Blue Version of the pcb you should adress your question in the other thread for this one ,
I have posted in the opther thread for this one.
Dan,
doqmemory said:Another D87 joins the world! Mic-Parts RK-87, Cinemag CM 13113 and body from chunger. It is quiet and rich sounding, complementing my other microphones nicely.
Mike
Ricardus said:Does he have the bodies back in stock with the graphics for the switch patterns and such?
