- Joined
- Jul 15, 2009
- Messages
- 2,301
craigmorris74 said:Thanks for all the help I've received so far. I want to try to bias the FET using the Room Capture software to measure THD. Do I measure from the drain of the FET for this method? Also, does the transformer have to be disconnected?
Craig
been a while since i did not used it , but from what i remember you set the pot very low resistance and then with the room capture you basically inject a tone in the mic, (without capsule only) and then you route the output of the mic trough a pre to Room capture and then once the FET start to open up while trimming the pot you will hear it and then you monitor the THD , just before it opens up the THD will be very high and then slowly trimm until you reach a minimum Value in the THD , it will be somthing like 0.3% IIRC and then you stop there , this method was very sucessfull and gave the exact same results as with a scope.
Just a tad more fiddlings
best,
Dan,
