kante1603 said:
Personal statement:
I got hundreds of PMs during the last couple of months on how to build this mic.
And I always replied and tried to help as good as I´m able to,guided guys with zero posts(!) through it,even sent them parts,but now it becomes way too much for me.I have had more than 25 mails from one single guy here recently.
People-please ask your questions here in the thread,that´s what it is for!!!
I know sending a PM is sooooooooo easy,and no one must feel bad or ashamed.
But doing this is really unfair:Nobody else can participate or discuss it.
And I´m not your private service-engineer nor will I support some people anymore when I feel they are nothing but lazy.
This forum is about sharing experiences,discussing things,helping each other,developing stuff and so forth,but not a cheap shopping mall with a full service included.
I say it again:Read the thread,if necessary two or three times:Most issues have been covered already,I´d say about more than 90%.
Learn at least some basic electronics or do some easier things like a D.I.-box,a simple mic-preamp etc. first,learn at least ohms law,what a dmm does and how to use it,improve your soldering skills and so on.There´s tons of infos on everything here in the forum and on the web.
Rome wasn´t built in a day,we all had to go through this.
With this in mind,best regards,
Udo.
So now I introduce my issues to the board ;D
I'm building the 87 using what Udo has identified as an older version of the Bhrngr B-2 Pro. The whole capsule/switch assembly is shockingly terrible and convoluted, so I started by just taking apart and gutting every last section as you can see in these pictures-
As you can see, there are tabs and pins inside with wire coming out of this plastic body section-
https://www.dropbox.com/s/00dhuld1ure98t9/IMG_20130614_175054.jpg
The top half of the capsule can be unplugged via a set of six pins, leaving you with this body section-
https://www.dropbox.com/s/9qbbnentub9rln6/IMG_20130615_170556.jpg
Now open up the top half of the capsule, and you can see the "sleek"
wiring for the capsule and switches-
https://www.dropbox.com/s/boymici39dhrjk8/IMG_20130615_171018.jpg
Then, I opened up the bottom half of the capsule assembly (the part that the top half 'plugs in' to) and found more capacitors. Why not? :
https://www.dropbox.com/s/qongi87ygmhh8pq/IMG_20130615_172512.jpg
So, with all this nonsense addressed, I've planned to cut all the switch PCB traces (except the shielding ones!) and run them through three separate holes that I'm going to drill through several layers of plastic, marked in this picture-
https://www.dropbox.com/s/ma8f7av30wdq6ec/IMG_20130615_175207.jpg
I have a lot of thin ribbon cable that I think will work fine, and will at least be as good quality as the switch->pcb trace->male pin->female pin->wire to body PCB path that it takes now
At least for now, I have a way to put the whole thing together. I'll be ordering components for the PCBs soon, I'll keep everyone updated. I intend to make this thing work!
Now I just need to find the most current BOM......
