AndersB said:when i turn the P1 clockwise I get some very ugly pops. on the scope it looks like maybe some DC or some very powerful distortion.
When i back it of a little is disapearing. I useing a tune for testing so its every time the bassdrum get's hit.
AndersB said:but it's not posible to get it near the +15 dB.
If you running the the eq unbalanced the output level is 6 dB lower than in balanced mode. That is probably your source of error.
Moses said:Hey guys..
Just putting together a BOM for myself on this.. Does anyone know if Ptownkid ever did do a kit for this project?
Im *trying* to spec Wima caps, should I be looking which range should I be looking at, there seem to be a few options out there!!
Thanks for your patience guys!!
Mo
Mo
_casio said:jarlemari -
Thank you! I've been following this thread/slowly putting together this project for months, and just happened to pull open the thread after a rather long hiatus.
An open question to everyone - for those of us who have boards with the original pin layouts and used omeg pots: has anyone put together a front panel layout to accommodate the slightly different spacing as a result of bending the pins? Or does anyone have an idea of the best way to go about creating and/or modifying one for a more accurate fit?
I'm hitting the home stretch on my console build and, having built two 492's and the ssl, I'm just down to panel layouts.
-drew
Ptownkid said:Moses said:Hey guys..
Mo
No i didn't get around to it. Money got a little tight around here for a while. It is in the works still. As for your cap question, don't get too bent out of shape about getting the most amazing (or expensive) caps out there. It's been shown time and time again that it makes very little difference.
