On the trafo/fuse note.. The 5532 docs say 8-16mA per chip, x 8 = 64-128 mA per channel... SOOO, for two channels 128-256mA total?
If I use a 15V trafo, that would mean 15V*.256A= 3.84VA... If I use a PSU such as the SSL9K, and a trafo with dual secondaries, would I double this (3.84VA per secondary)? If so, less than 8VA max is needed, which means a 10VA should be plenty (assuming no LEDs)...
Is this right?
For a 10VA trafo doing 2x15V, would the proper fuse value be 10VA/15V or 10VA/30V?
Plus some extra "headroom" of course.
