backstreets
Active member
I have two W492 equalizers that I use for as an M-S EQ setup in my mastering chain. I've been thinking about the idea of modding them from +-15 dB gain range to +- 7.5 dB.
I would also like to change the low cut from being 80, 20, 140 Hz to 80, 20, 40 Hz. As the 140 Hz is too high and I could use a 40Hz cut in-between 20 and 80.
I talked with Mazz (www.vintagecity.de) and he suggested that I'd check with you guys who have DIYed the W492 and see if you could help me out. From what he wrote to me I understand that I would need to change both pot's and resistors as well as caps and resistors in the Rc low-cut section.
It would be super if you could help me out on what I need to do and what to change to what to pull this off!
I attached the original W492 schematic as well.
Thanks in advance,
L
Thanks in advance,
L
