sorry tr7 gets hot it is the bc441. the voltages got to 4v on one start up but subsequently i have not been able to reproduce it. still consistently the same voltage no matter whether the op amp is installed or not or the switch elcos. I will triple check the resistors in this section.RuudNL said:What did you do to get the voltages to 4V? For some reason the buffer amplifier is still drawing too much current!
Did you lower the value of R37/R38? Doing so, this will only reduce the voltage drop, but not the current! A better way is to reduce the value of R55 and R56 slightly.
Do you mean that the BC184C (TR2) in the BA640 gets overheated? The collector resistor is 47 K, so there is no significant collector current. It should not get warm at all. Are you sure all components around TR2 do have the right values?
(Always difficult to troubleshoot from a distance....)
