promixe
Wow, there's been some discussion going on here! =) For some reason I stopped getting thread updates in the email... Weird.. Anyway:
RuudNL, thanks for your contributions to this thread. I have a few questions:
Would you have an opinion as to why your unit differs so much in LF distortion handling even with identical sidechains? What component are you referring to that would give erroneous superimposed harmonics onto CV?
Also, I think you might have mentioned earlier that you added 10:1 ratio mod to your compressor, is this correct? Or am I mistaking you for someone else? Did you calculate the values for that mod or did you use "empirical method" of just plugging in resistors and measuring until it matched the response? =)
Did you happen to use OPA2604 for this? Did you wire it as single-ended positive only supply?RuudNL said:I replaced the intermediate transformer by a differential amplifier.
But even in the original state (without my addition), the LF distortion of my compressor is lower than the version of for example Promixe, as you can hear in the posted examples.
