tommypiper said:
It's the noise floor, hiss. Seems too high. I'll repeat: It's higher in the compressed file. Is that coming from the 33609 or are you just adding a lot of make up gain which raises the original noise floor?
Sorry, not hearing the hiss, but I come from an analog world.
It could be the dithering that was added to the stereo samples to get them down to 16/44.1
from 24/96 that you're hearing. You said you heard it in the original clip, so the comp/limiting
with added make-up gain; there was easily 10db of gain reduction happening on the peaks, would
bring up the noise along with everything else. As far as the 33609 it's dead silent, I could not detect
any noise when I plugged my headphones into the back and cranked the gain.
Edit: Okay, I went back and listened, and yes the noise floor is present between the cycling of
the pattern. I had to CRANK my monitors to deafening levels hear it at all. Considering that
there's 12 microphones, mic-pres, eq's and various compressors feeding that drum sound. There's
also a tape sim plugin inserted on the drum bus before the compressor which adds a small amount
of "analog dither".
The noise is not coming from the limiter.
Mark
