maxheadroom said:promixe said:Some audio examples:
Can some one run the unprocessed file through their unit AND/OR the original 33609(C/J/JD)?
Original: http://dev.ax-design.com/electronics/33609/33609-test4a.mp3
Compressor IN (THD -4dBu / 100ms RECOVERY / +6 GAIN / 4:1 RATIO): http://dev.ax-design.com/electronics/33609/33609-test4b.mp3 - the 100ms problem was fixed by replacing R10 with 24k
Limiter IN (THD +4dBu / 100ms RECOVERY / FAST attack): http://dev.ax-design.com/electronics/33609/33609-test4c.mp3 - you can hear the distortion. I don't know what it would be attributed to (see next link)
Limiter IN + Compressor IN (setting are as above): http://dev.ax-design.com/electronics/33609/33609-test4d.mp3 - really distorted signal. Compressor smoothes the track, adds gain makeup, and then the limiter freaks out. It sounds like there is an overload somewhere along the limiter sidechain. Where would I look? It calibrated fine though...
Examples C & D sound pretty horrible if you ask me =)
Example B on the other hand really remind me of the classic neve-ish mixing desk sound. That one gives me hope =)
I would really appreciate if someone replicated same settings on their unit (DIY or original) and posted audio. I can provide space for it on my server if needed. Thanks!
hello promixe,
have you found a solution regarding your problem with the distortion of the limiter?
i have the same problem. especially on limiting the bass as single signal i hear great distortion when i turn the limiter on.
anyone else have this problem?
Qty Value Device Parts
DIODES
4 1N4004 D20, D21, D22, D23
4 1N5400 D16, D17, D18, D19
RESISTORS 1/4w pitch 10mm MF 1%
1 10k R-EU_0207/10 R24
2 200 R-EU_0207/10 R4, R5
1 rx+ R-EU_0207/10 R1 3k6 for24v
1 rx- R-EU_0207/10 R7 3k6 for24v
IC'S
1 317 LM317 IC1
1 337 LM337 IC3
CERAMIC CAPS 0.1UX50V PITCH 2.5MM
4 0.1 50v C2.5/2 C9, C10, C11, C12
ELECTROLYTHIC CAPS 50V
4 100u 50v CPOL-EUE3.5-8 pitch 3.5mm diam 8mm
2 3300u 40-63v CPOL-EUE7.5-18
PITCH 7.5 OR 10MM
2 HEATSINK FARNELL 1313891 , 1315516 , ETC
salomonander said:anyone know where i can find a schematic/technical handbook for the original metal knob version?
salomonander said:salomonander said:anyone know where i can find a schematic/technical handbook for the original metal knob version?
nevermind i found the original handbook. the schematics are pretty different in some areas to j/d, j or c version. MUCH more tantalums in the original. different cap values as well.... some styroflex etc. no suprise that the original sounds different....
