official GDIY51PSU Help & Support Thread
Hi all,
I have a couple of questions to ask (too many pages  for search ;D)
-What the value of the main fuse ? i'm in France main voltage 220V
I see in chunger thread 1.6 amp for + - 16v, and + - 24v.  125mAh for 48v. so 6,525 Amp max
But in Volker transfo it's print 188VA  :eek:
For me P=UxI so 188 = 220 x I
I = 85mA  ???
I'm lost !
-I buy wire to ptowkid but it's 24 AWG  :-\ (re  :-\  and :mad: no informations on website)
if i see here http://www.powerstream.com/Wire_Size.htm i need 20Awg ?
Is it good or i can solder this 24 wire
Thx a lot gentlemen  8)
Main fuse: T5AL250V
+16V/-16V and +24V/-24V rails: 2A
+48V: 100mA
This was supplied to me in the electrical wiring kit that came with the PSU case from Mr Cemal. I live in Sweden (240V).
I did a search and what I came up with is this quote from one of Mr Cemal' s posts:
"between 0.7mm (21AWG) and 1mm (18AWG) of ordinary copper wire should be fine."
I hope I could be of any help for the first time on this great forum.
Kind regards
Magnus
Thx Dr Gris
I don't have this infos i just ordered pcb and transfo  ;)
So i have to re-buy wire  :-\
hi everybody &
have a nice eastern also !
-just finishing the final cabeling of cemals dual power supply (btw. the most satisfying diy so far due to really nice prework ! )
still confused about grounding even after seeing all the photos here, with ground from psu board going to the fuse board ( as suggested ) and then to
the ground of the neutrik (?)
-where it hits the star ground via physical chassis connection of the neutriks ?
and one wire from psu chassis to star ground means that the 511x rack chassis is routed via psu board to the star ground ?
please , somebody explain it to me  ::)
i would have thought other way round ?..
greets and congrats everybody to their finished projects !
axel
When you say 'Dual Power Supply', do you mean that you have the new rack mount psu design that Cemal was working on? If so, where do I get one, huh? I'm out of space in my 51x bucket, and need to expand. What's up wif my sweet new psu solution, eh?
Brolik,
I have four left. Please e-mail me at [email protected]
Axel,
There are two grounds.
First one is the circuit or analogue ground. This is the ground that the regulator circuitry has as the reference for the rail voltages.
The second one is the chassis/safety ground that comes from the mains. This is the middle tab on the IEC.
The analogue ground comes out of the regulator board and goes into the fuse board. Comes out of the fuse board and goes to the 7 pin Neutrik.
The reason for that is that we need a ground for the status LEDs to function.
On the 511 rack the ground connections are jumper selectable. This is good because there are times that you may need to lift the module off the chassis ground due to hum. So I suggest you leave it selectable on the 511 rack.
However, you must tie the analogue ground to the chassis ground at the chassis star point inside the psu case.
On the output terminals of the regulator board there is a chassis ground connection. Connect it to the star point. Also on the regulator PCB there is a header/jumper immediately next to the input terminals which allows you to connect the analogue ground to chassis.. You can solder jumper it. Check to make sure both are joined and you are done.
Ok cemal thx for clearing up :D
i know there are two grounds but on the photos of the ready units above i could not see the front jumper cabeled so i thought i was
missing something here !
now i can finish the last connections and fire up !
greets as always
axel
Hey Axel,
Did not mean to patronise. Just wanted to clarify. Glad to hear all coming along well.
Kind regards,
Cemal
Also, how do you connect the sinks to the power supply boards, can you show us pictures of the guts?
Nicely done.  Beautiful.  So the Heatsinks are the sides of the cabinet.  It is hard to get those darn screws in there between the caps and the heatsinks I am sure ( i kept getting shorts because the shoulder insulators were out of alignment.
Thanks for the guts shot.  A really nice build.
I am very impressed indeed by how Denyle  got those screws but if you can align the holes  between the fins then you can always screw the regulators from the outside by having the nuts/washers inside. Alternatively if you have access to a milling machine you can shave the fins and again screw from the outside.
The other side is fins... which makes it hard to put screws in there... and invariably the spacing of the fins does not match the spacing of the regulators on the card.... (And in my case there was an aesthetic issue too... as my heatsink was the front panel..... and I didn't want to mess up the look of the fins).  In my second one, I mounted the heatsinks aluminum sheet screws from behind, and then as you say milled (i just drilled shallow holes) for the screw heads in the back of the heat sink, and then mounted the plate to the heat sink... with compound between... All the while thinking there has to be a better way.
"One wishes" that it were possible to arrange the board so that the regulators line up with the spaces between the caps.  Which would make it all a piece of cake.
Denyl's build is as clean as can be... even with the difficulties.... really great
