I was a little bit premature in saying that I had fixed my monitor controller Sad
I thought the issue was going to be fixed when I resoldered a loose wire going to the trim switch.
Unfortunately after resoldering the wire to the switch, nothing on the control board works. It looks like this wire wasn't the problem.
I have 12V going into the control board, and 5V after the rectifier so power isn't a problem
I have removed all connections to the trim switch altogether just in case it is bad in some way, but I don't see why this would cause a problem anyway.
Can you suggest anything to try next? I must admit, the schematic isn't helping me much because it's all to do with digital contro - not my speciality!
Do you think it's possible that the CRM chip is fried? I get the same result with or without the CRM chip in place when I turn the power on...
please check if any keyboard inputs are not connected.
I.e. pins 15....22 are on +5V thru pull-up resistors
and there are pulses at pins 2...6.
Check SPI going to A6833, 8,9,10 of microcontroller - if lines are not shorted.
Check without 74AC125 in case of whatever.
No prob, I have one spare control board, and can send it for free with
pre-prog'd chip at chip self cost + shipping. Feel free to mail/PM.
