the_inventor2
Member
Yes, there scratchy!Are they Scratchy?
If they are scracthy you should do 2 things before thinking about replacing them,
Scratchy pots can be due to DC leakage in the Electrolytic capacitors, so do a ReCap of all the lytic caps, those modules are more than 30 years old, so it's a good idead to do recap job anyway.
It's this doesn't work, it's probably dirt on the carbon track and oxidation inside the pot, so use Deoxit D5 and spray it through the small opening on the back of each Pot, Rotate very well and many times the POT after spraying.
One of these should fix
thank you very much - I'll be sure to do that!
Do you have any recommendation for balancing the output?
I think none of the suggested ones from back then are available anymore.
