"Rollo" Knobs for Altec, Langevin, and other Vintage Gear
mjrippe
GDIY Supporter
Brooklyn, NY
Following up on a request in the Black Market, I am posting my drawings of the famous "Rollo" knob for free use. The knob this was derived from was on loan from Doug @emrr so big thanks to him!
@thomasdf is hoping to do the 3D model and make files available.
-Mike
    2.6 MB
Well I had some unexpected spare time this morning so this is were I am right now :
This is a 2 grooves version, with a single set screw hole on the side. I seem to remember there are two set screws appart 90° from one another, one being through the indicator groove. I can easily add that.
I'll probably make a single groove, too.
I've kept all the edges / angles sharp, but I'd probably advise putting a little fillet to them, in order to make them a little smoother. If you have some high res pictures I can try to mimic the OG's edges.
I haven't modelled the brass insert
The TXT has to be changed to .STL in order to work
  • Rollo_2Grooves.txt
    143.9 KB
    633.9 KB
How is the set screw going to work? Is there some kind of standard brass threaded insert that can be used?
Edit: Looking at the drawing in detail I see there is a brass insert. Are these readily available??
Following. Looking great.
So these have a sort of circular hole? Like Ian mentioned re: set screw.
Would be great to someday have one that would fit a standard fader cap too as you mentioned :)
Give me the precise fader cap dimensions and I’ll do that, it’s quite easily done
For starters I wanted to do something true to the original. A rectangular piece of brass can be bent into a circular insert, drilled and tapped. Or maybe the original can be found ?
For my personal use I was thinking of having the screw hole drilled at 2.5mm and then tapped for m3 set screw + inside central hole at the correct size for the pot shaft. Milled in aluminium
Edit: here are some pictures taken from two different Reverb sales
    520.4 KB
    57.6 KB
    49 KB
    50.7 KB
    52.5 KB
