speakercoil
- Joined
- Apr 16, 2009
- Messages
- 138
Yeah that's one of the things I was wondering about. I was going off a schematic that didn't have any connection points indicated, so I wasn't sure where the connection was made... If it was right before R6 or if it was on both R5 and R6. Like I said I am a novice at theory so I wasn't sure which was correct. So I am assuming now just connect it to R6 then?
Assuming that is correct here is my moded schematic... With new values and the removal of 5 and 6 in parallel.
Let me know what else should be changed. I didn't add another resistor to ground as proposed, because I am not 100% sure where to put it in the signal path, or what value to use!
-Grant
-Grant
