speakercoil
- Joined
- Apr 16, 2009
- Messages
- 138
lol... Alright you convinced me... I will mod a chinese power supply and look at the pattern switching... Maybe down the line I will build both the gus recommended changes and the JJ... For now I will do the JJ first just because... well... It can use a cheap power supply.
Yeah I figured those resistors would be large, but the body should be big enough to hold everything if I space all out correctly...
OH! I had one last question... In this design do I have to worry about using high wattage resistors anywhere, or will 1/4-1/2 watt work. So far to be safe I have been sourcing 1watt resistors. I have sourced every part so far. Total cost is around 900 so far... Using all top quality components...
Resistors are a mix a mills, vishay (bulk foil axial), Takman, and Kiwame. The caps are a mixture of Siemens NOS PIO, and Auricap.
BV8 will be from Oliver, and Capsule from Thiersch. The tube I am still debating... I know someone recommended a m8100 instead of a 6AK5, but I also was recommended a Mullard 5654.
I am very excited about this build now!!!! It went from being a "let's see if this will work" project into a full fledged new design. Thank you so much to both Gus and JJ, because without them... Well this wouldn't be possible. Also thank you to everyone else who has helped so far!!!!!
Now... To hit the drawing board again and try and implement the pattern selection circuit.
-Grant
-Grant
