haima
sweeeet!
i really should finish mine soon... argh. too many projects!
but you edited it , and then it's 1279... :-XIgor said:POST Nr 1272!!!!!!!
Please tell me more! (concerning the switches that is)zayance said:I bought 20 chinese stepped attenuator on ebay for my Sontec the dealers name is hampton if i remember correctly, got me a good price for them, they are Vishay i believe.
Seems like we will be building same sontec, i went for forsell also ;-)
dagoose said:Please tell me more! (concerning the switches that is)zayance said:I bought 20 chinese stepped attenuator on ebay for my Sontec the dealers name is hampton if i remember correctly, got me a good price for them, they are Vishay i believe.
dagoose said:Thinking about the stepped switches; for frequency i'm going to use the calculations as vitalahde describes so with semitones instead of regular log. Has anybody done that already?
For the Q i will go for 12 steps switches because i think that is more then enough and for the gain i will also use 24 steps switches.
Both Q and gain are lin so i guess it's just a matter of deviding it in all the same values, so for gain it's something like 2k per step x 24 steps = 48k (almost 50k) and the centre will also be 0 automatically. Am i correct here or do i miss something?
I only did the calculation in the excel sheet, dunno about Jaakos calculation. It's simply his idea translated into numbers, his values probably not that different from mine.dagoose said:dagoose said:Thinking about the stepped switches; for frequency i'm going to use the calculations as vitalahde describes so with semitones instead of regular log. Has anybody done that already?
Anyone? ???
MrShhh said:Re stepped gain controls: I got around this by using 24 step switches with steps 1&2 tied together. That way you can't have the switch 'fall off the end' into an unconnected step. The center tap point is then step 13 and you have 11 steps either side of this (actually 12 on the 'anti-clockwise' or minus side but 2 are tied together with a zero ohm link). Done this way, you need 22 x 2k2 resistors giving 48k4 total which is only 3.2% off 50k.
What's really needed is a 25 position switch as then you'd have 12 positions either side of zero (the center tap point at step 13), giving +/- 12dB nicely. Or of course, use actual 23 position switches giving +/-11dB.
Then you can truthfully say that youe EQ goes to "11" ;-)
Bruno2000
I will make a pic of the place wher to drill a hole and put the pin in, hard to explain, you have to see..
