Dear Diyer,
After more than one year spend to recapping / cleaning / fixing my soundcraft 600 i'm now spending time to measure to improve a little bit the board.
First thing here is the frequency response of a recap and a non recap channel. Bottom end are lot better but no difference at the top end:
How can i improve top end response ?
So second thing is about THD. I first measure a huge total harmonic distortion and i was a little angry of it more than 0.5ù of THD is too much!!
Then i start moving masters level like OSC level and what's a surprise THD get lower when OSC level is not to 0:
But 0.144% THD is not acceptable too so i unscrew the master channel to check solder on PCB and everything and at the moment when Master channel faceplate was isolated from the chassis ground THD became normal =>0.04%. Is not so bad
My question is how to solve this ground issue i can not keep my master channel on piece of paper like that !! And why moving OSC level change THD level ?!!
Thank you for your help
