Bruno....
Had a couple of phase problems, and traced it back to the Polarity switch on the 9k5 preamp. It turns out, on mine anyway, the default phase is 3 hot, 2 cold, 1 gnd. Which is switched from normal.
I was wondering if I am using the wrong type of relay perhaps (OMRON G6A-234P-ST-US-12VDC), but I just found the aromat
http://pewa.panasonic.com/assets/pcsd/catalog/ds-catalog.pdf and it appears to be the same.
The Aromat DS catalog says that it is possible to special order reverse polarity Relays but lead times are long unless someone knows where to go.
I could just fix it by leaving the polarity light on but there must be a better way.
Did I use the wrong relay? Is there a right one? Know where to get it?
The default position for this relay is shown in the photo.( iPhone photo through a jewlers loupe!)
Anyway, I was thinking that the default position of the relay is incorrect or unexpected, or is it just a bug in the board, in which case, what do I do? I am thinking a little creative crossing of the leads on C4 and C5?
Did some more looking. I really don't get it. If the part is wrong, then the other three switches should also operate incorrectly. phantom should be off when I turn it on, etc.
So what gives?
