recnsci
[quote author="Samuel Groner"]
Now why's that? I (and many textbooks) think that Nyquist told as differently--it appears however that phase response needs to be below 180° at the unity gain frequency only. Any smart guy out here who could shed some light on this? Thanks!
[/quote]
Reread those textbooks, Nyquist doesnt state that phase must be above -180
for closed loop system to be stable. It can drop below if it comes back up at
some point.
I will try to write easy-digestable version of Nyquist criterion:
Asume A(s) is Laplace domain transfer function of some amplifier. Draw
that function in s plane. Asume that feedback network is frequency invariant
with gain K. Then, closed loop system is stabile if and only if A(s)
doesn encircle (-1/K, j0) point. This holds under asumption that open
loop function A(s) doesn have poles in right half plane.
To put it in practice, lets analyse halcroamp.gif :
amplitude graph represents disctance of A(s) from (0, j0) (center of
s plane) for some angular frequency, phase graph represents angle
between positive half of real axis and line that conects some
point on A(s) and (0,j0).
So, A(s) starts at positive half of real axis, 240dB from (0, j0). When
we increase frequency, A(s) moves into lower right quadrant of s plane.
Till 500 Hz it reaches negative part of imaginary axis (phase is -90 deg).
At around 500Hz we have bump to 250dB and phase drop at -270 deg.
A(s) rushes trough whole left half plane and lands somewhere near
positive part of imaginary axis. That is, A(s) made 3/4 circle clockwise
in s plane, at pretty much constant distance from (0,j0). Past 500Hz,
phase increase (that will result in CCW direction of trajectory) but
amplitude decreases. Thus, A(s) moves trough upperleft quadrant
of s plane, and reaches again negative part of real axis (when phase
reaches -180 deg) at around 400KHz. This is important point
and we will take note that gain at this point is around 35-40 dB.
After this A(s) crosses into lower left quadrant and make lobe till it
reaches (0,j0). Angle of "entering" (0,j0) is -90 deg. We take note No2
again and say " well, only if we could buy these SPICE opamps; with
real opamps we will have some problems here".
A(s) crossed negative part of real axis at 250 dB and recrossed it at 40dB.
Now lets see whats with that (-1/K, j0) point: no feedback -> that
point is at -infinity and system is stable; apply feedback and point
start to move along real axis in positive direction; when feedback
reaches -250 dB point enters A(s) lobe and system is unstable; when
feedback reaches -40 dB point exit lobe and system again becomes stable
and it it remain stable till feedback reaches 0 dB, that is for unity
gain.
What this means in practice: closed loop amp will be stable from unity
gain till 35-40 dB of gain. Above that it will sing. In theory it will be stable
at open loop. In real world it will very much sing. This could be a bit
counter intuitive behaviour for amps, but this stuff happens in control
engeneering. Beware of Note 2. Samuel had chosen ideal amps, so
at unity gain amp is dead stable. With real opamps, unity gain
stability could be problem. Especialy if this is power amp, and output
driver is some slow device.
cheerz
urosh
[/quote]
some point.
gain.
cheerz
urosh
