Rocinante
Have we gotten anywhere with the Mic/line issue? I've been recreating the gerbers in eagle to try to fix the issue to no avail.
Rocinante said:Have we gotten anywhere with the Mic/line issue? I've been recreating the gerbers in eagle to try to fix the issue to no avail.
Yes they did but they also put a pad in front of it as well otherwise it would saturate on line levels. Also, as best I can rememeber, this was only done on switching modules. Nominal output was -8dBu for a _4dBu inputRocinante said:I'm going to rack it as I want to use 24v keeping more like the original plus hopefully higher headroom.
Ian, didn't Neve wire a switch in some of their preamps to the 10468 so it could be also used in reverse for the line input? Could we do that with say an EA10468?
The Carnhill is the equivalent of the 31267 which was the standard Neve line input transformer usually wired 10K:600I was going to do that with my Neve-ish summing mixer but just got Carnhills instead.
The tap was to replace a 20dB input pad on the mic. Helios line inputs were generally unbalanced and switched in at the secondary of the transformer.IIRC the lustraphone transformers had a separate tap for line right?
dogears said:I think it's fine the way it is with the understanding that there can potentially be 48V present on the inputs at any time.
Whoops said:Sorry mate,
I completely Disagree.
It's a receipt for disaster, there should never , ever be Phantom Power on a Line Input, ever.
Thanks for your work Dogears, I don't want to diminish your work in any way, but it's my honest opinion from 20 years of Engineering.
Rocinante said:Dogears, thanks for the modification man. Naturally I had just added the relays in Eagle and then saw your post.
I think this will be my 4th version of the Helios. I am fairly certain I am going to use the 22113 again like in the version 3 that Whoops so gracefully shared. That way I have the option of adding a xfmr.
dogears said:Alright, added three relays for the input and changed the selector to a SP3T. Now in line, phantom is no longer connected to the input. However, you can still fry gear if you try.
