Rocinante said:Whoops to the rescue. PM me your address Whoops, so when I get PCB's done I can send you one
Thank you so much for the offer, I would love to try one of your boards out.
Thank you so much
pm sent
Rocinante said:
Possibly place a large value resistor (1 Meg) across the pot to ensure the electrolytic always has a dc path to 0V even if the wiper lifts a little. And/Or make sure you select a very low leakage electrolytic.dogears said:I have a layout with just the first gain stage (preamp) using a pot for testing. It's a brand new CP pot, but it's got some scratchiness when adjusting. Is that just a consequence of the way the NFB is applied with this design? Any tricks to address that?
dogears said:Couple of options. You could pad the input, or you could use a very large resistor for the first stage gain (~220k gives you only 1.6 dB gain) and increase the gain resistor in the second stage slightly, to around 10k. This would bring it back to unity gain through, with a minimal loss of headroom.
Actually you could also try it without a gain resistor at all, which should turn the preamp stage into basically a unity gain buffer.
letterbeacon said:Thanks for the suggestions. Do you think I even need the pre amp section? Could I not go from the input TX straight into the EQ circuit?
Whoops said:Ian (ruffrecords) has a project that is a 3 band Helios EQ, just the EQ section, it seems that project suits you better. Ian made that project open source.
http://www.customtubeconsoles.com/ruff-records-pcb-empporium
http://www.customtubeconsoles.com/diy
Rocinante said:Whoops to the rescue. PM me your address Whoops, so when I get PCB's done I can send you one, albeit it'll be awhile. Slightly off topic but what do we know about the 22117? I saw a dual 22113 card on one of the helios sites and I'm also trying to figure out where that went.
