Hello everyone.
After reading this and other forums several times (well.. almost) I decided to buy Takstar CM-60 mics. So it's all your fault, guys
Still probably several weeks before the parcel arrives but I'm already looking for advice.
First off - the slotted grill. I read so much about the importance of rounded edges, capsule being as close as possible to the front etc, so I wonder whether shaving of those thick, sharp slots wouldn't be advantageous? There's mesh beneath them, it seems.
I know a good machinist who could take care of this, no problem.
The other thing is fet bias. Here I need some help and finger pointing
RuudNL mentioned several times that Takstars need bias adjusting. And a trimpot place. Unfortunately I'm electronically dumb. Half-dumb anyway. I have proper tools, I know a cap from a resistor, can solder smd circuits without problems (been soldering even 32-pin chips once upon a time) but I wouldn't recognise, say, a voltage divider even if it bit me in the ass. But I can design you a logotype for your mic Or make a custom industrial/loft style lamp
What I need is: " replace Rxx with trimpot of xxOhm and adjust from this point to ground (or across this element) till the V is such and such."
Any other suggestions in the field of replacing elements with better ones?
I do not record music/vocals. Field recording definitely. So not looking for warmth nor character.
Thanks in advance - Paweł
