e.oelberg said:once again, do we need latching or non latching ?
poctop said:Actually there is no standard for 7 pin wiring so you can actually make your own scheme if you will
just make sure it follows the logic from the psu to the mic pcb and you will be fine ,
I just have an habit of following the Neumann scheme for my cable , I have wired my cable like this ,
but since this one have 2 pattern control it deviates a little bit from it , but as said if you are using a Gotham cable
reserve the blue wire for Circuit ground and the red wire for the heater as those are the biggest gauge to handle more current
as said you can define your own cable configuration from psu to mic as long as it is following the logic.
here is an example :
Perfect, Thanks a ton. I'll upload pictures after the build is complete. Should be sometime later today.
1-audio +
2-audio -
3- (Relay control 1) to OMN
cable shield = up to xlr tab as well
4-heater
5 B+
6 Pattern control ( relay control 2 ) to Fig 8 on mic pcb ,
7 circuit ground
CBarx said:poctop said:Actually there is no standard for 7 pin wiring so you can actually make your own scheme if you will
1-audio +
2-audio -
4-heater
5 B+
7 circuit ground
CBarx said:Just doing some final adjustments on the PSU before plugging in. I'm noticing that the B+ voltage at terminal Block 1 is at 200v, which seems high based on what I'm reading. Using trimming resistor R4, I can get the voltage down to about 173v before the resistor bottoms out. Any thoughts here, or is sending 200v ok (I thought we were aiming for 120v)? Thanks in advance!
shaggy said:CBarx said:Just doing some final adjustments on the PSU before plugging in. I'm noticing that the B+ voltage at terminal Block 1 is at 200v, which seems high based on what I'm reading. Using trimming resistor R4, I can get the voltage down to about 173v before the resistor bottoms out. Any thoughts here, or is sending 200v ok (I thought we were aiming for 120v)? Thanks in advance!
No load? (Mic not plugged in.)
