Winetree said:"As far as I can tell, the relays are really only supported (mechanically) by a single pin to board solder on the outer relays and get the rest of their mechanical support from the point to point soldering.
Has anyone tried shaking their built pcbs to see if they get any vibration of the relays because of that?"
Haven't noticed any vibration problems. But I did have to make sure the relays were tight together and had to sand the 2 outer edges at 45 degrees in order to fit the mike tube over them. Also there was noted some problems with vibration noise with the 2 large poly caps on the top back side of the P.S.B. Glue them down.
PhatPlanetStudios said:Good day 251'ers,
So I've completed my build with a GE 5-star, Beesneez capsule and body and the new mic all powered up and functioned without a hitch! Great docs, pics and posts made the build a breeze. Thanks to all! Upon initial listening, the 251 clone sounds thin, bright and lacks low end. Sitting next to our vintage Telefunken U47, the 251 doesn't even come close in sound quality. Pretty disappointed, so now I'm trying to figure out what I did wrong. Some questions are; B+ (grid) voltage. Diagram says 120V & I've seen 110V in the posts. Any impact in sound quality with the grid voltage? Are there any key component changes that differ from the Mouser BOM+Styroflex Caps that I should be aware of? Any insight would be greatly appreciated. Thanks guys!
dmp said:Doublecheck the transformer wiring also - that can lead to thin sound
duantro said:Any thoughts/ tips on adjustments to the circuit to work with an ac701k?
poctop said:PhatPlanetStudios said:Good day 251'ers,
My first Reflex would be to try a cheap chinese CK12 capsule type to rule out any capsule problem at first ,
it is not impossible that somthing is wrong with the capsule as it plays a major role in a microphone ,
Hope this helps, if not i would defo check the wiring and component value in the HZ bridge, a little substition in a high Megohm range would totally kill it. i would also be intested to see what the capsule looks like when it is polarized.. i would also check to make sure that your 2 backplate are properly isolated this could messup the polarisation scheme for the pattern.
Dan.
granger.frederic said:Dear Lauritz/PhatplanetStudio,
congratulations you have a near perfect Elam 251 plot : see the original plots at http://recordinghacks.com/pdf/telefunken/ElaM-250-251-Manual.pdf ,
you're near the specs...
but if u want to be sure , double check B+ with the mic plugged : max 110V , check the heater : 6.3V , check that all the HiZ sections are perfectly cleaned , check the capsule voltage before the 8Mohms resistors : around 60V
If your capsule is a bit low end shy for your taste, try to decrease capsule voltage to 55V (reduce the 0.5MOhms to ground), increase the 30Mohms grid resistor to 300Mohms and put a 100uF on the cathode instead of 22uF. U could increase the output coupling capacitor up to 3.3uF as well ....
with the high end response, assuming your plot is accurate , i would increase the output LP filter by increasing the 120pF to 220pF or even 330pF ... (or more to taste)
regards
Fred
