trans4funks1
- Joined
- Feb 4, 2013
- Messages
- 328
Thank you for the info Dan.
trans4funks1 said:Hi Woot,
Thanks for explaining about the diodes. Now I'm scratching my head wondering why there aren't 3.
poctop said:Looks like a wet tantalum to me , but they may have had different type over times , as Metal paper, polyester also,
Why Not polyprop
Here is a shot ,.
http://www.youtube.com/watch?v=rJx9TdJSFRI
Dan,
your guess now,
Marc Duchesne said:Where's the mic donor body from Dan...
Marc Duchesne said:Yep, where have you got the donor body from...
Might be interested to built one...
Woot said:Hi DAn,
Could you tell me the max voltage for the 200v secondary of the power trafo?
How much power do I need for each secondary?
Would this work?
http://www.don-audio.com/g-pultec-power-trafo-sec-220v-9v-5V
Matt
micaddict said:An alternative body could be the BeesNeez Ela M. It was on sale (100 dollars off) until last weekend. Perhaps Ben and Veronica could prolong the sale for Group DIY members who act quickly? The Australian dollar is relatively cheap now, too, especially for Europeans. The body will still be more expensive than the HT-11A, but it's built like a tank.
It does have a bigger diameter (closer to the original, actually). Well, a little too big should be less of a problem than too small. Would it be a problem, Dan?
Too big is actually a good thing for DIYer, what is the lenght of the Beez mic body.
LEt me know i will check the lenght of the pcb .
DAN,
micaddict said:Oh, I forgot to add that it can be ordered in any of the standard BeesNeez colors, with no upcharge. These are professional paint and powder coating jobs.
DAN,
Sleeve diameter, from the back of my head, is 51 mm or 2 inches. I'd have to check for length (I believe it was mentioned in older adds), but perhaps Ben or Veronica could chime in.
Anyway, here's the current add (without sale):
http://www.beesneezmicrophones.com.au/store/index.php?_a=viewProd&productId=99
Thanks Danpoctop said:This traffo has enough power no issues if you use the 9V for the heater and the 220V for the B+ , you might want to tweak your R1 and R2 resistor to drop it the right amount tough , you can do the math and it will work fine , the resistance were based on the 200V output from the HT-11 psu , also you need to aim it a 110V not 120V ,
i use a 250K pot for this and 75k r1 and 75K R2 ,
Dan,
micaddict said:Sleeve diameter, from the back of my head, is 51 mm or 2 inches. I'd have to check for length (I believe it was mentioned in older adds), but perhaps Ben or Veronica could chime in.
