So after working on and recording with so many of these mics over the past two years, I thought I'd look into building one. What I can tell you all with dead certainty, is those schematics are wrong! absolutely wrong. I've never ever seen a 3.2uF output cap in these, or the 1.6uF output cap for the non-export version. I've worked on at least 40 of these. I've seen some weird things, like an 8 MEG grid resistor (very low bass response), and the most obvious fake AC701k tube ever (painted over AC761) but almost every mic i've seen that had the original wet tantalum output cap, it was 1uF. You'll get better results adjusting low end with a grid resistor than an output cap. If you're going for the original sound, stay away from those 3uF output caps. They aren't doing you any favors, and they are simply the result of a bad schematic. I find anything 100 Meg or higher for the grid is just fine.
