LevinGuitar
- Joined
- Jun 13, 2019
- Messages
- 405
Yes, it is similar to the Matador ELA M251 that Chunger sells, detailed in ELA M251 Inspired Microphone - Build ThreadWill this random chinese mic (apex460) mod would be close to a Elam 251? What change would make it closer or just better sounding?
I would like to use Tim capsule and Moby T14. Any suggestion is welcome
All of the pdf links on the first page of the thread work for me. I used them extensively in the past several weeks for my build. You may need to highlight them manually and select "Go to ..." from the context menu (if Chrome).Hi all, I just ordered the boards for this project and am in progress sourcing the rest of the parts. I only made it about 1/2 through this long thread but am having trouble following along some of the discussion because the layouts and schematic links in post #1 are broken.
I’ve got a few questions, hope you guys don't mind if I put them here (and I will finish reading the rest of the thread over the next couple days)
Firstly, can someone help me with a new link or message for the schems and layouts pretty please!
Is there an updated source now for the 3.3 mF cap that is out of production on the mouser bom?
Where can I order a Tim Campbell capsule?
I am planning to run the Haufe Xformer So far. Are there any sources in the US? The Don website is looking like about a month lead time. I would be interested in any discussion about pros cons of other transformers also. I love the current Tfunk USA tone but wondering if I could get the same result with a cheaper transformer and tune the circuit for the low end as I’ve read a bit about here by changing component values.
Lastly, I’m looking at the Apex mic for a body donor. Any reason not to use the Apex power supply case as well for the PS build? Any other mic bodies or PS cases I should consider? The beesneez looks great but is an extra $500!
Thanks a bunch and looking like a fun build!
In My experience, the small L laminations and the high primary DCR coupled with the low inductance give the real T14/1 a special sound that other transformers - no matter how you swap the components around - won't replicate.I am planning to run the Haufe Xformer So far. Are there any sources in the US? The Don website is looking like about a month lead time. I would be interested in any discussion about pros cons of other transformers also. I love the current Tfunk USA tone but wondering if I could get the same result with a cheaper transformer and tune the circuit for the low end as I’ve read a bit about here by changing component values.
I do have your ct12 and it’s truly a stunning capsule. I don’t believe haun or josephson sell direct though…at least not single pieces.I have and so have many of my clients. I realize that I am too busy these days to be able to fill everyone's orders. I would highly recommend the Haun MBHO capsule or the Josephson capsule.
Change anode resistor from 100k to 47/50k,PSU needs more current also with ecc81,reduce the dropping resistor values after the diodesWhat circuit component values would recommend to be changed to optimize for the 12AT7?
Those are the changes that I made for 12AT7, 47K cathode resistor (instead of 100K) and 33K for the two PSU resistors after the diodes for B+ (instead of 68K for Matador PSU, 75K for Dany PSU).Change anode resistor from 100k to 47/50k,PSU needs more current also with ecc81,reduce the dropping resistor values after the diodes
This should be the same as @Moby 's (excellent!) T14/1, so look at this post.Is there anyone that could point me in the direction of how to wire the Haufe T14/1 (6 wires) to the the board/connector. Trying one out against my already installed AMI. From all accounts it looks as though two of the leads are connected on the secondary side its just hard to tell which? Red/blue/blue/red on secondary and green/green on primary.
