Baderjoe
Member
That sounds good. You have proven the amplifier is working. The issue is, the output impedance of a signal generator is low (about 50 ohms), so it can drive almost anything. The output impedance of the capsule is extremely high, so it can’t drive a low impedance input. Do you have a value resistor in series between the grid and the capsule’s output lead? Generally, this is a 1 Meg ohm resistor.I built the microphone to Dany's (Poctop) specs so there wasn't any modifications. I was assuming it is either:
A. issues with the HiZ section (I have no way to measure that part)
B. Capsule is damaged
C. Some kind of short at the relays.
I was able to inject 1k sine wave into the grid so I am thinking the amplifier section is functioning. I am not sure what to do next.
Thanks Baderjoe for your help!!
