micaddict
I've started a separate, feeler thread concerning a Beesneez body, taylored for this project.
http://groupdiy.com/index.php?topic=55176.0
Henk
Henk
I really do urge you to either find the wet tant or make space for PIO.Melodeath00 said:The TE-1501 appears to be aluminum cap, not wet tant. It's for the coupling cap. It does indeed look like the caps Telefunken USA uses quite a bit in their reissues.
You could increase the grid resistor and reduce the output cap value. Go up to 250M and down to 1uF.trans4funks1 said:I have a question regarding the capacitance value. I recall seeing discussion regarding opinions about values other than 3.2uf but I am having trouble finding reference to the discussion in my notes.
particularly if your using a Chinese Ck12 capsule as they don't have the LF response of the real capsule or an accurate clone.250M and down to 1uF.
JessJackson said:Well done Dan in taking over the project... It was too much for me to get done with everything else going on at the moment.
I do think maybe take a look at our last design (version 6.5) as this was the closest i feel to perfection in utilizing the relays.
The cathode bypass components would be floating on back of tube base hence displayed off of the board.
trans4funks1 said:JessJackson said:Well done Dan in taking over the project... It was too much for me to get done with everything else going on at the moment.
Hi Jess,
I took a look at the board you posted an example of to learn how you planned to use the relays and I can not figure out how it can work. I drew a schematic, as I did with Dany's layout, and I am hoping I am missing something you can explain. I can't unlock the puzzle of how the board you posted a image of provides all 3 patterns.
Any clues?
Thank You.
trans4funks1 said:Hi Dany,
Yes I downloaded it right after you posted it. It was very helpful. Thank for posting it. I had thanked you and I sent you that message about C3 too.
I am interested in the idea that there may be several relay switching solutions to achieve the same goal and I enjoy the exercise of thinking it through.
Thank You.
The other problem I foresee is that it won't matter where you drill the holes as the board in current dimensions doesn't over lap the struts. Make it wider, then it'll be too fat for the Alcatron et al mic bodies.
The only thing I can see is that the copper ground layer is exposed on the left and will therefore short to the mic body. Is this OK, or ideally should it be isolated?
Or if this is really a bad idea
Woot said:The other problem I foresee is that it won't matter where you drill the holes as the board in current dimensions doesn't over lap the struts. Make it wider, then it'll be too fat for the Alcatron et al mic bodies.
micaddict said:BTW, do we need an opening for a pattern switch?
