- Joined
- Jul 15, 2009
- Messages
- 2,301
kcguitar said:After building 2 fantastic Tim Campbell equipped sounding ELAM's this past weekend, I just wanted to mention that with the HT-11A bodies, the relays are a VERY tight fit and the 2 outside ones will rub against the body tube. I was somewhat able to alleviate this by angling the 2 outside relays in so that their outside corners sat a little closer towards the center K2 relay. Also I cut the leads for C4, R6, and R4 short enough that they did not protrude through the board so that they relay wouldn't have to sit any farther out than it needed. Finally I was able to carefully file the corners of the relay in at a 45 degree angle. My boards still flex just a bit when assembling the mic from the relays hitting the body tube though :-\
Anyways hope that helps with anybody that has yet to use these boards in conjunction with the HT-11A's.
would you be able to post some picture of this achievement in my case i did not have to file anything to make it fit, lets make sure when you install the relay that they are fully engaged and as close as the board as possible and not slighlty crooked , it is very easy to leave a gap there or position the relay just sidewayss, what i usually do is that i solder one pin of the relay and then heat it up again and push down on the relay to give it his proper position and then i solder the rest of the pins, also make sure your ouput cap is not too fat to make the board flex when you install it , I agree tough it is a close fit but it should slide in properly as in my build.
also make sure the orientation of the pcb is not slighlty deviated also cause i also notice once that the rail on the HT-11A can have a slight tolerance sideways that you can fix by just pusing them straight. once this is perfectly straight it should slide in but it is indeed a very close , so you have to make sure all the small details are on your side.
Again, Congrats for your build and i would be delighted to see picture of those babies on this thread,
and an audio sample would just be divine with CT inside
Dan,
