The Rude Tube Build / Support Thread (MAJ + PSU)
glbaudio said:
About the PSU's C5...is really difficult for me to find a 1µF 400V condenser with a 10mm pitch!
a Wima is 22,5mm pitch...what you have used? I have some Elettrolitics Condensers...but are not the same!
What's about this cap?
Any advice? What have used who have already builded?
Thanks in advance
Thanks in advance
You can use this : http://fr.farnell.com/panasonic/ecwf2w105ja/condensateur-450v-1uf-5/dp/1854917
Hey guys,
I almost have finished my boards but I got some strange problems with the Tubes and PSU... if you have any idea please tell me what's happen... Drask is helping me but I want to know if any of you have done with this build? any if you can post some pictures maybe it should help us :) Thanks!
and now the problem is that I see 350V on the PSU without boards but when I connect two boards 5 mn later the tubes are turns off and I got 350V again on two boards :(
any idea?
Thanks for any advice....
Ok, I think that this tubes are not the best one :)
http://www.musikding.de/Active-parts/tubes/NOS-tubes/6SH2P-EV::2906.html
I think that I must to change them but just before getting them can I use 5725 or 6AS6W?
http://www.radiomuseum.org/tubes/tube_6as6.html
jandoste said:
Hey guys,
any idea?
Thanks in advance
If you do another batch you probably need to modify the pcb for a few standard size lead spacing to help those arround the world fine stuff to fit.
jandoste said:
Hey guys,
any idea?
Check the tube heater regulator, is it going into thermal shutdown?
What type of heat sink do you have on that regulator? I'm asking because the ones I have fit the silk, but are about 1.75"-2" tall.
Intrigue!
Anyway I'm just gonna put my questions here at once, I'd like to get back to the building :D
- I'm looking for the right kind of inductor for L1, any suggestions on anyone that will (preferably) sit on the board.
- The big connectors, which series?
- The voltage rating of the non-notified film caps on the BOM
- Is http://www.banzaimusic.com/EF806S-JJ.html a proper alternative for the ef86, it says so on the site, but I'd like to hear you guys feelings about it, or about which tubes to use in general (Jandoste?) And where to find that 6AS6?
All for now, I suppose....
Good Night,
M.
Hey M.
you can get some 6AS6 from this guy,
http://cgi.ebay.fr/1-tube-5725-RT-6AS6W-CV4011-GL5725-CK5725-/300364705814?pt=FR_JG_Collections_Radios&hash=item45ef21b016#ht_500wt_919
RATMNL said:
Intrigue!
M.
Sorry for the Double post.
Bernd,
Is the case you built the prototype into (and therefor also the fpd) a modushop slimline 2u?
for the system holes.
Mark
Hey Guys,
Can you tell me please that my grnd points are write?
I don't get any signal with the Tranxfos[In] all XLR's connexion ok! When I send a signal[1k] I hear anything but Vu meters see very low signal :(
DI connexion is ok too...
The Rude Tube has no VU meter. The 1mA meter shows the current, going through the 6AS6 tube, not the audio level. When you turn up/down the bias pot, the meter should move accordingly. I still haven´t got any pcbs, so that I can´t help you with the ground question.
regards
Bernd
