Skylar
RE: capsule mounts & the EQU47
Option A = Thiersch STS-7
http://www.thiersch-mic.de/en/estm_produkte.html
This option is closest to the original.
You'll need to attach the EQU47 capsule mount insulator to the capsule mount disc using m2 set screws (included).
Insert an M3 screw through the bottom of this assembly into the capsule mount itself.
Step 6 in the following image:
Resulting capsule mount height should be 45mm, identical to that of the U47.
Right now, I have a Thiersch capsule and STS-7 mount coming my way.
When these arrive I will, of course, verify the capsule height.
It looks like Thiersch has some new, cheaper mounts—I will probably buy these and try them out as well.
Option B = Chinese-style mount
burdij is selling these in the BM. Similar options are available through lewilson & Peluso Microphones
The bottom of these mounts have two M2 holes, spaced 8mm apart.
The EQU47 will not work with smaller sized holes or different hole spacing than this.
If you choose to use this mount style, you will not need the capsule mount insulator part.
Instead, you'll attach the capsule mount directly to the capsule mount plate with two M2 screws through the bottom of the plate into the mount base.
Step 5 in the following image:
If you use this option, your capsule mount height may be slightly lower (possibly higher) than the ideal 45mm spec.
Use shim(s) to arrive at 45mm height. OR experiment with different capsule heights!
RE: EQU47 basic dimensions
I do not have the drawings/dimensions in front of me now, but I will put together an image and/or PDF of basic dimensions that are of interest.
Here's what I can tell you from memory:
Outside diameter of tube = 60mm
Outisde diameter of headbasket = 63mm
This is a longbody mic—exact length coming soon.
There is a lot of room inside the tube area, so many circuits could be used.
RE: EQU47 connectors
This mic body is designed for the Binder 691 series 7-pin connectors.
I will be arranging a group-buy for these, so that you can get them with your mic body.
