ppa said:are there any PCB holders will be sold?
thanks
azander said:ppa said:are there any PCB holders will be sold?
thanks
perhaps post #393 is what you're after unless the plan has changed. <http://www.groupdiy.com/index.php?topic=30124.msg395885#msg395885>
Kingston said:ppa said:are there any PCB holders will be sold?
since all holes in the bracket are M3, you have plenty of choice here. Most "nuts and bolts" stores will a have variety of 90-degree corner brackets just for this.
If all else fails, you could use zip ties. I've done this for a mic build. Good for isolation as well, compared to metal brackets screwed tight near PCB traces.
Rossi said:Yes, using mic transformers backward is pretty much standard around here (and I'm sure other places as well). Interfacing a tube to 200 ohms isn't so different than interfacing 200 ohms to a tube. One is step down, the other is step up, but the impedances to be interfaced and the levels are similar.
ppa said:yes, this is right, it's possoble using an mic input tranny in a mic, the screen pin of this trasformer should be connected to 3 pin of the XLR connector, I suppose.
the metal can to the mic earth, I suppose.
MATTI said:I´m not in a hurry with this project, you can wait for something this good!
-Did you happen to write down the point to point connections for the M7 psu and if
could you send them as I´m bit challenged with these ( Against DIY mentality )
Matti
Skylar said:In this mic, I've connected the EA2622 screen and case to ground.
ppa said:Skylar said:In this mic, I've connected the EA2622 screen and case to ground.
theoretically transformer screen and case should be connected to output XLR connector's pin 1.
Obvius, if mic's ground is connected in the pin 1, than screen and case are connected in the pin1 the same.
