Skylar
Finally, next round of samples coming next week.
synchroman said:Oh but it will effect the heat inside the mic.... Bad for the tube, transformer, and capsule
Again, the capsule is in a separate chamber. The heat from the resistor will not affect the capsule.synchroman said:Heat vs. Capsule:
M7 capsule are made of PVC and PVC does not like heat...
It makes sense that the inside temperature of the mic will increase if the resistor is not heat sunk to the aluminum body.synchroman said:Heat vs. Transformer:
"Regarding the heat sink resistor, the power dissipated inside the mic is the same regardless if you have the resistor on the body tube wall or inside, but the one that has the resistor inside has a higher temperature inside the mic that means all components are subject to a higher heat. Parts like the x-former do not like heat and in average a higher temperature with a nickel core x-former will reduce the inductance what means less low end."
quote from Oliver Archut of TAB Funkenwerk
http://recforums.prosoundweb.com/index.php/mv/msg/22971/0/0/0/
synchroman said:Heat vs. Tube:
"Degenerative failures cause the performance of the tube to slowly deteriorate with time.
Overheating of internal parts, such as control grids or mica spacer insulators, can result in trapped gas escaping into the tube; this can reduce performance. A getter is used to absorb gases evolved during tube operation, but has only a limited ability to combine with gas. Control of the envelope temperature prevents some types of gassing. A tube with very bad internal gas may have a visible blue glow when plate voltage is applied.
Gas and ions within the tube contribute to grid current which can disturb operation of a vacuum tube circuit. Another effect of overheating is the slow deposit of metallic vapors on internal spacers, resulting in inter-element leakage.
Tubes on standby for long periods, with heater voltage applied, may develop high cathode interface resistance and display poor emission characteristics. This effect occurred especially in pulse and digital circuits, where tubes had no plate current flowing for extended times."
http://en.wikipedia.org/wiki/Vacuum_tube
"Tube life is sharply dependent on temperature, which means that it is dependent on filament or heater operating voltage."
http://www.vacuumtubes.net/How_Vacuum_Tubes_Work.htm
