tommypiper
Cool. Fingers crossed.
Skylar said:-I would like to see further polishing on all headbasket parts before nickel plating.
fazeka said:Skylar said:-I would like to see further polishing on all headbasket parts before nickel plating.
Hi Skylar,
The mic body looks like it's coming along nicely.
Regarding the plating of the headbasket parts... I'm no plating expert, but I think I know a little bit about it.
If it's possible, I would think a more luxurious look to the plating would be to have the platers copper-plate the steel before the nickel (chrome) plating. In the plating world, this copper-fill step is somtimes foregone due keep costs down. The copper fills in all the machining or other marks/imperfections (e.g. due to machining, etc.) in the steel. After the copper-fill, it is buffed and then the nickel (chrome) is plated next. I'd like to think that the copper also serves as a "primer" of sorts, giving a better bond: the copper bonds better to the steel and the nickel (chrome) bonds better to the copper than nickel (chrome) straight to steel.
Maybe it was copper-filled, but it doesn't look like it to me.
Just my 2. Otherwise, looks spot on for the most part! ;D
canidoit said:How much do you think the total cost would be to build one of these complete?
Case, power supply, internals, etc?
Is the MK-7 and P2P the only DIY build suited for your U47 body?
Will there be a kit available for this mic body?
Yes, yes. I forgot that it was brass! :-[Skylar said:All the headbasket parts are brass, so for practical purposes the nickel plate should adhere to the brass just as well as it would copper (being that brass is a copper alloy as I'm sure you know).
Skylar said:I think that the most cost-effective solution to improving the bright nickel finish is simple:
1. spend a couple of extra minutes on the polishing wheel before plating
2. leave the parts in the nickel bath for 150%–200% longer
Skylar said:I agree that the copper plate before the nickel plate would help fill in any deep scratches or imperfections, but it adds another big step in the process.
Plus, I doubt that they have a copper plating rig.
If it turns out that these guys are not capable of providing a good enough finish, I will use a local plating shop which does laboratory-quality work.
Two-stage nickel plating using copper or zinc is probably standard for them.
desol said:So, would you go for something that sounds good...or looks good?
I remember you asking me this a while back, Pier.ppa said:What are the internal dimensions available?
Will some holder points be inside the mic body to hold a PCB?
thanks
kind regards
Pier Paolo
thanksSkylar said:I remember you asking me this a while back, Pier.ppa said:What are the internal dimensions available?
thanks
kind regards
Pier Paolo
[Sorry I never got back with you!]
I will post a diagram soon.
audiovisceral said:I can't quite tell from the pictures so excuse me if this is an obvious question, but is the cable jack on the mic body going to be something that we can install ourselves, or is it built directly into the body and not interchangeable?
riggler said:Skylar,
Can you make me a set of bodies with the height cut in half, and with slanted grills for my M50 project?
Eh, have to check the widths... Was going to gut a pair of MXL990s for the purpose...
Anyway these bodies are RAD!! Props man.
SIXTYNINER said:please dimensions are as in the original?Skylar said:internal dimensions
