Haha! That's my eye. I do that every time I photograph one of mics during the build. Those little mirrors are just too tempting not to make funny faces in.
Sounds good, I will try different ones. Reichelt Electronics has Toshibas 2SK117. Ordered. Hope the will work and the finest Waterfall "Noise" will end ...I haven't had a chance to record with them yet but hopefully pretty soon. I'll be interested to see if any noise develops.
I bought a SCM-2 stereo mic direct from Ningbo in China
https://www.aymaudio.com/product/stereo-diaphragm-condenser-microphone-scm-2/And the top capsule made what I can only describe as a waterfall kind of sound. It turned out to be a bad FET which I replaced and all is quiet and serene since. Ironically I record waterfalls, among other nature sounds and prefer the real thing to imitations by bad FETs![]()
Thank you for posting this. I have some 2sk117's that are suppose to be On Semi original but they look almost like yours! I am building two of these so I installed the 2sk117 in one board only. If it does not work I will use a 2N3819. I have those on hand.I ve also isolated all high impedance parts from the PCB for testing on one Mic. I used Teflon turret pins for connecting through the PCB. 2n2 Styro, 1G Ohm, 33pF, 100M Ohm connected to Fet are connected together in the Air without touching the PCB. I have also checked other built 47 Mics. The most 47 manufactures did it the same way. But on my tests it had no impact compared to directly soldered high Impedance parts on the PCB. It worked perfectly without noise a few minutes and appeard then a few minutes later again with an introducing "pop" - like disconnecting the Phantom Power for a Second. The Signal remain clean but as said, with much much more "white" noise. Like a waterfall. I hope
these "bad" SK117 Fets are causing the issue. I bought them from an Electronic Store in the Germany, Kessler.
Btw - would a Fairchild 2N3819 Fet also work? I have them laying around. 2N3819 are also used in U47 Fets builds. Comparing the original Neumann 47 Fet Schematic vs UTM 47 Fet Schematic I can not see any big difference. Except of the missing 10dB Pad / HP Switches / 33M/68M Ohm Resistors and the replacement of the BC182 and BC212 with BC550 and BC560. And the Fet itself for sure..
EDIT: Fairchild 2N3819's from the picture are working perfectly with these UTM PCBs. No noise anymore. Silent.
The SK117 Fets like these on the Picture do not work properly.
Bought, thank you!These at Arienne's suggestion;
https://www.aliexpress.us/item/3256...t_main.52.21ef1802paiSCu&gatewayAdapt=glo2usa
The disk is about 5cm across, so it think it should fit.Does anyone know if this PCB fits an M147-style body?
I did the mouser BOM last week and it's missing quite a few components. I'm actually working on the rest now, since I didn't double check prior to ordering them.Schematic and BOM are available under "downloads" right on the product page on the UTM website.
