U47xfet PCB from UTM / IGS?
i have seen it, but how do i know whether a capacitor is a film capacitor or not....
I'm just referencing the pcb to see which are polarized or not, and also checking some of the photos at the beginning of this thread. There's 3 styrene caps, one should've came with the kit, the other two I ordered from Banzai, along with the 2sk117.
SKU21152Styroflex 100pF
SKU273972SK117
I'm going to give this build a go and have ordered a UTM47LB kit and a UTM0547f transformer from UTM.
The hardest part is deciphering the BOM and sourcing the components. Its like trying to solving the da Vinci code.
Doesn't help when TimGs Mouser BOM is only 50% complete.
Anyway I got the Mouser BOM and hunting down the rest. Nothing like the thrill of the hunt.
The only thing I have to go off is the schematics and the build picture which are a bit ambiguous.
I sent Igor from UTM an email asking him for clarification of some of the caps used as there has been some confusion as to what type they were.
This is what he said.
C2, C3 - styroflex or ceramic
C4, C9 - WIMA or similar
C6 - Tantal (0.33uF)
C2, C3 I think I can get 18p and 33p Polystyrene caps, just waiting on conformation on stock. If not Ceramics it is.
C4, C9 WIMA caps are easy to get but I might go MKTs.
C6 He said tantalum but I can only get them in 35V. Would they work? If not an Electrolytic it is.
C10 Elna caps are high quality Japanese caps and are easy to get. Should use them for all Electrolytics.
Anyway I hope I've got things right.
What's similar to a WIMA cap?
Aim for C0G / NP0 - values so low will more likely than not be those materials by default, but you'll wanna make sure.
I'd stick with known-brand Japanese electrolytics - Panasonic, Nichicon, Rubycon, Elna, United Chemi-Con.
See above.
Film capacitors (PET, PP) - you'll be hard-pressed to hear any differences between the same value but different materials. Well, outside of deluding yourself, that is...
Are you guys using 550 and 560 "B" or "C" transistors? I read that the C have a higher gain rating. Not sure if this is a good thing or bad. Thanks!
I used BC550B and BC560B with hfe between 300..400 in similar schemes. They are closer to BC182B and BC212B from the original scheme. I paired T5 and T6.
    106.7 KB
  • utm47fsch.pdf
    159.5 KB
  • BC182B Fairchild.PDF
    33.9 KB
  • BC550Fairchild.PDF
    55.7 KB
Finally finished this build.
Went for the Flat K47 from Arienne Audio. Excellent capsule.
Wouldn't fit in a 103 shell. Its about 5mm to long. I couldn't see any other way of mounting the transformer.
I put it in a 47 shell from AliExpress.
https://www.aliexpress.com/item/100....order_list.order_list_main.23.26381802Jz7qwo
There are cheaper ones of this there which look the same.
Had to cut back the 2 small ridges with side cutters so it would fit in.
Looks good and sounds great.
Used the B version of BC550/560 but if I do another ill use the C as it could do with a more gain if the C will do that.
    4.9 MB
    3.8 MB
    3.8 MB
    3.8 MB
    4.3 MB
    3.7 MB
Hi @Plonker !
Many Congratulations!
You managed to complete a nice project!
Maybe you can post some sound tests.
Have you matched the hfe for the BC550/560 final complementary transistors? What value do they have?
*It is possible that using version C with too high hfe will cause autoscillations, become unstable. Not getting enough output level?
No didn't have that many 550/560 Bs so I didn't have the luxury of testing a bunch to match.
Do however have a truck load of Cs.
Output levels are OK and on par with my K2. I do have a modded Studio projects C1 and a Microphone parts T-12 which have higher output levels so its always nice to have more.
Seeing the BC550/560s are now obsolete although you can still get them, what would you suggest as an alternative?
Although this sounds nice, ill put up a sound file soon, the output level is low more so then the K2. I'm pushing the mic pres on my interface fairly high.
Would matching the BC550/560 hFes help with this or should look elsewhere? I have ordered som more 550/560 Bs so I can try and match them as bes I can.
