Hello friends!
I have heard good things about Igor's transformers (igs member here on the group), UTM Transformers, from many DIY enthusiasts. I became curious.
After testing different transformers (neutrik, cinemag, beyer or even custom, modified by me from those found in the DI-box for a suitable ratio) I decided to try the UTM brand as well.
I ordered 4 pieces of UTM0587. Easy order, excellent communication, fast delivery.
The transformers are very well built, consistent (they all measure the same), with a large and quality core.
Impatiently I quickly ran tests in a U87ai-inspired clone, cardioid only, with a 797 CY002 capsule in a B2-Pro headbasket,2N3819Motorola IDSS=8.1 point-to-point construction, on the workbench, partially shielded. The feedback capacitor between 330pF...750pF, gave me a nice Neumann-ish character, varying between U87ai and U87i. The truth is that I can't decide on a specific flavor, so I'll use a multi-position switch. Clear sound, great headroom.
I am convinced that with another capsule I would get a U67fet(?) sound
I am glad for the decision to test these truly professional transformers.
Comparisons with other brands and sound samples I will post later.
I recommend with all sincerity
UTMtransformers.
Thank you Igor for your kindness and professionalism!
Micolas
