Hi all,
I was hoping someone could help me conceptually grasp the inner workings of the stacked RC circuit the GSSL uses when release is set to auto. A tall order, perhaps.
I will outline my understanding, and if I’m wrong, I’d really appreciate being set on the right path.
The circuit appears to use shared capacitor(s) for both attack and release phases. There’s an attack resistor feeding the cap during the charge phase, and a release resistor to handle the discharge phase. This would also explain why these units do not have any settings that would result in the release time being shorter than the attack time - they are acting on the same capacitor and such a setting would result in any charge being instantly drained.
Assuming so far I have not made any horrific errors, enter the stacked release. Would I be correct in thinking that the intended attack time set by the pot would apply only during the duration it takes for the smaller capacitor to charge, during which both capacitors would be charging at this rate while current is passing through the capacitors. Once the small capacitor is charged, the larger capacitor would then switch into a new, longer attack time to charge the rest of the way, as it now has the small caps release resistor acting in series with the main attack resistor?
I would assume there is no sudden switching, but rather a gradual transition between these extremes as charges build.
Am I thinking about this all correctly?
Thanks for reading, if I’ve said anything stupid please correct me, I am just trying to learn.
