Thanks gonna go read it now!Me being in audio design mostly microphones I strongly recomend to read this Reliable Capacitors
It's an interesting paper, however it fails explaining how Dissipation Factor and Dielectric Absorption correlates (or not) with distortion, except for a rather anthropomorphic blurb.Me being in audio design mostly microphones I strongly recomend to read this Reliable Capacitors
It is long overdue, considering capacitor technology has changed a lot since, with much improved AL electrolytics, C0G ceramics and PPS films, and almost extinct polystyrene and polycarbonate.
You should write the articleCyril Bateman wrote his series of articles for Electronic World in 2002/2003, and a sequel in Linear Audio in 2015.
I'm not aware of any significant work since. It is long overdue, considering capacitor technology has changed a lot since, with much improved AL electrolytics, C0G ceramics and PPS films, and almost extinct polystyrene and polycarbonate.
AFAIK, the last Bateman paper was about DA, but did not show correlation between DA and distortion.
Indeed these RIFA capacitors were absolutely inferior, although Studer engineers thoroughly vetted them. It's called an industrial accident. Not as big as the one that put down thousands of computers, TV's, appliances, whatever... Many people do not throw their Revoxes to the bin, very often they recap them and keep them or put them for sale at a premium. Of course, apparatus with less noble lineage get thrown out.That is with Revox, Studer the case and many many more electronics. It's all obsolete after a decade and will be thrown in the bins, because too expensive to renovate and overhaul.
You don't need to be a hen to appreciate eggs.I myself have been a professional sound engineer for about 25 years, but I have never heard a clear difference between different capacitors. (But maybe I just used 'good ones'...)
Mivel több mint 20 éve foglalkozom elektroncsöves stúdiómikrofonok (Neumann, Akg, stb.) javításával, fejlesztésével, szerintem jók. Sok paramétert kell mérni és hallgatni. A szigetelési ellenállást általában minden darabhoz megfelelő feszültségen mérem. Erre a célra egy Radiometer IM6 Megohmmeter műszert használok, csőmikrofonnal nagy zajt tud okozni. Ez a műszer 1000 teraohmig mér, a tesztfeszültség 1 voltonként 999 voltig állítható. A kapszulákat is a névleges polarizációs feszültségen kell mérni. Az SSE SX1 Interference Supressor kondenzátorokat nagyon jónak találtam (fémezett polipropilén). Igaz, hogy "dobozos" kivitelűek, de hosszú, 30-40 mm-es csatlakozókkal rendelkeznek. Még mindig sok probléma van a 100 MOhm - 1GOhm ellenállásokkal, 0805 méretű SMD ellenállásokból készítem "létra" elrendezésben, epoxi vákuum impregnálással. 47 és 10 MOhm egységektől. ("made in Japan") Sok sikert és jó egészséget ehhez a szép munkához!csak ne akarj felrobbantani semmit. rosszul próbáld meg. szeretek egéren vagy digikey-n keresztül rendelni, de csak olyan kondenzátorokat kínálnak, amiket az adatlap szerint "általános célra" vagy "motorhajtásra" vagy "nagyfrekvenciás kapcsolásra" használnak... hangra soha semmit. Az ehhez hasonló dolgok...
https://www.cde.com/resources/catalogs/MWR.pdf
Amiről soha nem hallok hangos körökben beszélni...mindig wimáról, solenről vagy sonicapról beszélnek...
Vagy ezt...
https://www.vishay.com/docs/26022/mkp1839.pdf
Úgy tűnik, a specifikációk megfelelnek, de ezek a márkák jók a kimeneti kondenzátorhoz, mondjuk egy csöves mikrofonhoz?
I vaguely recall forum member Sam Groner doing some work quantifying nonlinearity in electrolytic capacitors.Two things I would need:
I have neither of them (used to, last century).
- a good audio analyzer (AP or equivalent)
- patience
That's right, I had forgotten about this article.I vaguely recall forum member Sam Groner doing some work quantifying nonlinearity in electrolytic capacitors.
Sam's article FWIW he had to come up with a custom measurement rig to resolve exceeding -150dB.
Edit- oops the Linear article is no longer free.
Quadrature Bridge Measures Harmonic Distortion in Capacitors
This article considers the measurement of harmonic distortion in capacitors using a bridge circuit. Each arm of the bridge consist of one resistor and one capacitor. The bridge is driven in quadrature, such that both the differential and common-mode output voltage are nominally zero. The article introduces a procedure to construct a capacitor with very low distortion contribution, which is used in the reference arm of the bridge. The resolution of the bridge is estimated to exceed −150 dB. Measurement results for various capacitor types are presented. These show that parts with ceramic C0G dielectric have more consistent, and generally speaking also lower, distortion than Polyester, Polypropylene or Polystyrene film capacitors.
Linear Audio, Volume 12, September 2016
This article is co-authored by Scott Wurcer.
Maybe someone will make bigger cog/npo caps
I have in certain situations. Clearly in some equalizer circuits. In the T filter EQ I built there was a clear difference between Wima PP and other PP caps. I’ve never heard a difference in coupling caps. I wouldn’t say they are never audible or always audible.You can talk for hours about the 'sound' of capacitors.
One thing to be careful about in uncontrolled listening tests is that the value of the capacitors being compared are closely matched.I have in certain situations. Clearly in some equalizer circuits. In the T filter EQ I built there was a clear difference between Wima PP and other PP caps. I’ve never heard a difference in coupling caps. I wouldn’t say they are never audible or always audible.
The value of the caps tested were selected within 0.1% of each other. I bought 100 pcs of each type and selected. I wasn’t screwing around with this console build.One thing to be careful about in uncontrolled listening tests is that the value of the capacitors being compared are closely matched.
