matta
I can't speak for the meters as I used the 'correct' 1DC mA meter with a scale from 0-20, I know many are using VU meters, so that may impact things somewhat.
Matt
Matt
sinestaraudio said:Hey Matt,
super neat wiring, very tidy!
Pete
kambo said:hey Matt, i see your twisted wires are off_centered about 1:100000000th of a mm ;D
you should be able to get correct reading by adjusting
VU adjustment trimmer...
far right is 20db or whatever point on VU you want... feel free to do your own scale...
once you mark your 20db, then you markup your 8db and so on....
I know this issue. If you use Farnell's ST7, add 220 and 680 Om
to get 1ma full scale (was described some tens posts ago),
When calibrating 20 db, be sure unit is calibrated before for 3.000v/8.00db
to get good stereo link. After first 3v/8db calibration let unit work 5-10 min and check again.
a year and a half ago when I built my first tremelo pedal I never thought I'd be building something like this.
AAAAAAAAAAAAAAAAAAAAAAA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!if you supply square control V to 2254c, it becomes a dynamic tremolo box
