haima
jandoste said:EDIT : Yep, was 100 ohmI got the neve sound now
glad to hear you got to the bottom of it! looking good
haima said:jandoste said:EDIT : Yep, was 100 ohmI got the neve sound now
glad to hear you got to the bottom of it! looking good![]()
kambo said:you get use to it after some 6 units ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
if you read the calib_pro carefully; its actually easy. patient![]()
pacemaker said:Hey Igor,
i was looking at the pics of your unit,
what did you use for non audio caps ?
regards,
francois
I ordered 100 of 4153 some time ago, can send 8 diodes, as one-time action,has anyone got some spare 1n4153 diodes they could sell me?
I don't want to use the mouser replacement option unless IGOR says they are cool!
Is this the relay for the 2254c
http://uk.farnell.com/tyco-electronics/fx2-d3226/relay-pcb-dpco-12vdc/dp/9913920
are the switches DPDT on/on types?
jandoste said:hello All,
I have almost finished the n2254 but two/three bug is discoverable for me.
1 -Gain is not function properly: I have no signal change with 1 +2 +3 +4 +5 + switch and when I switch to 6th I have a level too high!!!
I tried what Igor says ;
"before clipping.
Check the reistors on gain switch; if all is fine according to schematic:
feed +10 db signal to input, crank the makeup switch till output starts to clip,
no compression (put comp threshold to +10); take a scope and check the output of
2254C
with 1k load in parallel, it should have about +26..28 DBU max undistorted
signal at its output.
Adjust second half of BA283 (output section) for minimum distortion @+27dbU,
by turning 5k trimpot located near the 2N3055.
For more info about quiescent current for Neve class A check the web."
2 nd: threshold!
when I turned to -12 dB I think it does not work! I have no compression with the thresholdwhen I switch to -20 it works !
Maybe I got some problem with cables (grounds)?
Any idea ?
