Hi Pete,
its Igor's kit... after the first burn... i have replaced it, just incase... fitting is the same... from my stock 1290 parts.
it only starts burning, i if go CCV too much... i have tried on my ba283 board (neve 1290) its almost the same problem...
on extreme CCV setting same resistor getting way too hot. check the other topics for it... there seem to be a burning problem,
on ba183, if the trim_pot is not set correctly... i think i am ok on that.... i am on the safe side for equal clipping adjustment.
good thing i made some 1290's
i have almost calibrated my units, with 33609 testProc.
but i have to set my make_up_gain i click CV, and use it as 0db gain. i click CCV is -db...
so my +2db is set to 0, 0 set to -2db on scale....
if i set full CCV to 0, as it suppose to be, then i am having problem as -0.7db on the output, i can get 0 db, but then when i adjust RV2, i can only get -0.7db max...
with one extra click set to 0, everything seems to make more sense. i have plenty of room to calibrate...
with this adjustment i have finished section 3 and 4 on Igors Simplified version of testProc
sorry for the English
