First class work. Is that essentially a 500 series rack you have there?
hey pucho, no transformer, just the capwhat are you using for an output transformer?
pucho812 said:unbalanced out then? NO matter still looks great
gemini86 said:pucho812 said:unbalanced out then? NO matter still looks great
NYD one bottle was always unbalanced 10k out.
3nity said:Man that preamp looks so cool and simple to build!
Is there a chance we see the psu schematics.
Thanks.
I will post schematics and pcb file for this in a few days, I'm away from my shop at the momentIs there a chance we see the psu schematics.
aronaut said:I built a few of these in different housings a couple years ago and used rca black plate 12av7's without any problem, then for this build I purchased GE's and they all sounded like crap, they had the larger grey plates. Found another batch of nob black plate RCA's on ebay and they're all working fine...
they should look like this
aronaut said:Is that essentially a 500 series rack you have there?
in concept, yes. dimensions and pinout, no.
I like the simplicity of the mechanical construction, especially the end frames and the support for the card connectors. I am thinking along the same lines for my next generation tube mixers. Is that a standard square section aluminium you are using? Do you cut, drill, tap it yourself or do you have it done for you?
pucho812 said:gemini86 said:pucho812 said:unbalanced out then? NO matter still looks great
You can balance it out with a transformer. There have been version that had it. most used a 4:1, 10K:600
Thanks.
I got a PSU sch that was designed by dave for it although dave's didn't have phantom. But then again who needs it
