AC Sound Pi-3141 Pre-Order (PYE Comp) 2nd Round!! PREORDER OPEN!
stevenclements said:
Have my case...
only one of the PCB's (yeah I'm a goof) the other is on order.
THANK YOU for the Mouser cart... ready to order now.
Anyone have a link to the knobs?
Are these the ones?
http://ca.mouser.com/Search/m_ProductDetail.aspx?Davies-Molding/1500AU-BLACK-LINED/&qs=sGAEpiMZZMuiwDVLTMm01ajIGS4kAMb6V0%252bTv0RgI2A=
Have my case...
Are these the ones?
Allied Electornics doesn't have an order history (drives me nuts) Here are the small ones:
https://www.alliedelec.com/search/productdetail.aspx?SKU=70097809
I always have to double check the big ones cause they have so many different sizes.
Aaron Marci found these on Mouser
Smaller Knobs - http://ca.mouser.com/ProductDetail/Davies-Molding/1510AH/?qs=/ha2pyFadujrUgPg1/sA6O7cgb4nyXIT0wlO%2bgfqsYQ=
Larger Knobs - http://ca.mouser.com/Search/ProductDetail.aspx?Davies-Molding%2f1500AU-BLACK-LINED%2f&qs=sGAEpiMZZMuiwDVLTMm01ajIGS4kAMb6V0%2bTv0RgI2A%3d
I copied the previous cart and updated it to include enough knobs for a stereo unit
the cart is here - https://ca.mouser.com/ProjectManager/ProjectDetail.aspx?State=EDIT&ProjectGUID=21765FC6-F15D-4DA2-B601-0CF69821FEC6
Abe... can you suggest a power transformer on Mouser?  I'd like to add that to the cart as well then I think pull the trigger and order
Someone can check if this is correct, but I think you need this one and some other tidbits if you are using one of Dan's cases.
Mouser P/N's:
553-F117X Power Transformer
693-6200.2100 IEC + Fuse drawer
568-NC3FD-L-1-B Female XLR Connector (2X)
568-NC3MD-L-1-B Male XLR Connector (2X)
Patrick
So how do we check this?
Mouser P/N's:
Patrick
The power transformer is the only one I have a question about.  But as far as I can tell it should work.  Abe might want to check it out to see if he see's anything odd.
Patrick
shabtek said:
when will round 1 preorder be shipped?
I believe round 1 circuit boards have already been shipped. I recieved mine already up in Canada & I know at least one other guy up here who has also recieved one. Maybe try sending Abe an email or PM.
